Port to Slot
Nt2bfkwit
Member - Posts: 27
Posted: June 08, 2003 at 5:45 PM / IP Logged
Does any know how to covert port to slot.   Is slot better than port?
Maxst
Silver - Posts: 866
Posted: June 08, 2003 at 10:18 PM / IP Logged
Your tuning would be changed.
I need quality equipment, feel free to donate.
D148l0
Copper - Posts: 57
Posted: June 08, 2003 at 10:28 PM / IP Logged
Maxst, I beg to differ... if you use the right formula, a port is a port no matter if it's round or slotted, so you can tune it at will...
Nt2bfkwit, you may want to take a look at the vent size topic in page 2 (here's the link: https://www.the12volt.com/installbay/forum_posts.asp?tid=14508&PN=2 ) where you can see bberman's explanation/formula to make the conversion you want.
d148l0
Maxst
Silver - Posts: 866
Posted: June 08, 2003 at 11:30 PM / IP Logged
true... then why change? if your gonna have the same sound.
Nt2bfkwit
Member - Posts: 27
Posted: June 09, 2003 at 12:07 AM / IP Logged
Thanks for the input.   I'll check out the link you gave me D14.
bberman1
Gold - Posts: 2,314
Posted: June 09, 2003 at 11:24 AM / IP Logged
Nt2bfkwit if you want a good copy of those calcs send me your email address.
Platinum - Posts: 12,488
Posted: June 09, 2003 at 11:46 AM / IP Logged
A slotted port reduces the port noise to almost nothing because of the larger area that the air is able to move. That is the difference between a ported and slotted port.
Nt2bfkwit
Member - Posts: 27
Posted: June 10, 2003 at 10:23 PM / IP Logged
Hey bberman1, here is my email demboyfosho@msn.com
Thanks for the help.  One more thing the box I plan on fabricating requires two port per woofer.  Would I have to first figure out how to combine both ports to one, then covert to slot?
Nt2bfkwit
Member - Posts: 27
Posted: June 10, 2003 at 10:24 PM / IP Logged
Sorry bberman1, I misspelled the email Demboyzfosho@msn.com
Nt2bfkwit
Member - Posts: 27
Posted: June 15, 2003 at 11:19 AM / IP Logged
Hey BBerman1, I didn't get that fomula from you.
