MB Quart NA2-400.2 Amp Clarification
dertitan2
Member - Posts: 12
Posted: September 23, 2020 at 3:08 PM / IP Logged Link to Post Post Reply Quote dertitan2
MB Quart NA2-400.2 Powersport amp stats the following: "This switch will set the amplifier to have a full frequency output or to filter out high or low frequencies. The NA1-400.2 offers either a bandpass or a high pass filter." I am getting myself confused, you can select HP or OFF or LP, the manual states the amp has a 60hz subsonic filter, now where I am confused is this subsonic filter at 60 when it is set to off or other, i ask this because this is going to be feeding a set of polk audio db652 2 way 6.5" speakers on a motorcycle in the faring, Polk audio advised me to set the HP amp to 60, but if the subsonic is at 60 not need to adjust HP
I am probably just over reading what the manual says
Direction and clarification would be appreciated
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
