Pulling my Hair out - Please Help!
graemesimpson
Member - Posts: 24
Posted: June 24, 2003 at 9:11 AM / IP Logged
I have an MR2 mk2 and have built a custom sub box to go behind the seat, using the Volume calculator for "Wedge Encloser 2" on this site, it gives the result of 0.38433 Cubic Feet.  Now several questios arise, how the hell do I find out how many Litres this is as some manufacturers give the woofer spec in Litres??  Secondly, would an 8" woofer such as the JBL GT2-8 work in this unit.
Basic dimensions are:
Basic Measurements are Width = 22.4" Height 1=9" Height 2 = 4" Depth = 7" thickness = 3/4"
Graeme
DYohn
Platinum - Posts: 10,741
Posted: June 24, 2003 at 12:14 PM / IP Logged
1 cu ft = 28.31687 litres
Generally, an 8" sub will work well in a 0.36 cu ft sealed enclosure.  So it looks like you are on the right track.
DYohn
I can't find the specs for the GT2-8, but the JBL GT800 8" sub will work well in a 0.36 cu ft sealed enclosure.  So it looks like you are on the right track.
graemesimpson
Member - Posts: 24
Posted: June 24, 2003 at 12:22 PM / IP Logged
Many thanks DYohn, really appreciated.  One last thing though, how the hell do you get from Cu Ft to Litres ?????
Graeme
DYohn
Posted: June 24, 2003 at 12:31 PM / IP Logged
Multiply the cubic feet number times 28.31687.  So, your 0.38433 Cubic Feet enclosure is the same as 10.883 litres.
graemesimpson
Member - Posts: 24
Posted: June 24, 2003 at 12:44 PM / IP Logged
MANY THANKS.....I have regained my Sanity once again.
Big thank you from a dumb brit :-)
