remote wire fused ?
cosmic charlie
Member - Posts: 24
Posted: July 01, 2003 at 6:48 PM / IP Logged
   Hey all, I've heard that you should fuse your remote turn on wire is this nesessary, if yes what sized fuse should be used. I dont have one now but I'm upgrading to an Alpine cda 9813 soon and don't want to screw it up. Would the 9813 install instructions cover this.   Thanks for all input  CC
Cosmic Charlie
auex
Platinum - Posts: 5,041
Posted: July 01, 2003 at 7:03 PM / IP Logged
Generally it isn't required to fuse the remote turn on lead due to the fact that is so low of a current that it couldn't do any type of damage and most radios have an internal circuit braker for this wire. If for some reason you need to add a relay then you would need a fuse then.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
cosmic charlie
Member - Posts: 24
Posted: July 01, 2003 at 7:38 PM / IP Logged
thanks, wouldn't want to screw things up.CC
Cosmic Charlie
esmith69
Gold - Posts: 1,511
Posted: July 01, 2003 at 7:49 PM / IP Logged
Technically it's not required, but it will definitely not hurt at all if you just put a simple inline fuseholder on there.  I know some of the older head units (3+ years old) came with inline fuseholders already connected to the remote turn on, presumably because they did not incorporate a circuit breaker inside the unit like auex described.
The " Basic Car Audio Electronics" web site recommends (not surprisingly) to do a fused relay to protect the head unit.  While this may not be necessary, having it there will not do any harm at all and a relay and fuse will set you back like 2 bucks.  If I had a $400 head unit I'd probably be putting it on there, but that's just me.
Ethan
Donate to the12volt.com
Sebastian018
Silver - Posts: 364
Posted: July 01, 2003 at 7:53 PM / IP Logged
If you want to add a relay do it this way;
85= Remote from the head unit (usually Blue)
87= Constant Fused 12+
86= Ground
30= all the remote inputs on the amps
Hope this help
cosmic charlie
Member - Posts: 24
Posted: July 02, 2003 at 5:59 AM / IP Logged
Hey guys, thanks alot for the useful information. I think I will incorperate something either a fuse or a relay into the rem. wire just to be on the safe side. Thanks again to all who responded. I love this site.    CC
Cosmic Charlie
