Low voltage readings w/2 new Opti Yellow
purplexcel
Member - Posts: 20
Posted: August 10, 2003 at 10:32 PM / IP Logged
Just looking for some opinions. I just installed a Lightning digital cap into my system. I have 2 Optima yellow top batteries,but I'm still only getting a reading of a maximum 12.0 volts. I bought the cap off of ebay and it has a dent in it. Can this dent be causing the problem that I'm having? Do I need another cap? The batts are brand new and have been checked out to be OK.
Any insight will be appreciated.
I am a former IASCA competitor.I competed from 90'-94'in FLA. I once took 4th place honors at the Spring Break Nationals in 94'w/my Purple 87'Hyundai Excel. It was one of the top cars 51-100 am.
auex
Platinum - Posts: 5,041
Posted: August 10, 2003 at 10:52 PM / IP Logged
Check all of your other connections. Make sure you have a good clean ground, make sure your fuse isn't corroded, make sure there isn't any corrosion on your wiring. You should also take a meter to the cap and see what voltage you are getting, the cap voltage gauge could be messed up.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
