04 sunfire
jeremy1
Copper - Posts: 52
Posted: October 13, 2003 at 5:37 PM / IP Logged
i know i need to use a integration harness to replace the head unit in this car but i'm wondering if theres anything else i need to know and if it uses the same dash kit as th 02 and 03 thanks .
you will still be here tomorrow but your dreams may not.
tom small
Member - Posts: 36
Posted: October 13, 2003 at 6:37 PM / IP Logged
Instead of relocating the radio with an extension harness, many companies make class 2 integration modules to retain chime functions, etc...   I use soundgate - the part is called "GMCHIME" and simply wires in behind the radio.  This way you don't need to shove your radio in the trunk.
