adding amp to factory headunit 02 Trailblazer
Elliesguy
Member - Posts: 20
Posted: November 09, 2003 at 8:51 PM / IP Logged
I have a 2002 Chevy trailblaer. I've probed all the wires for a sufficiant remote turn on.  but have not found one. My head unit stays on when the key is takin  out untill you  open the door, dont know if that matters, please help, thanks..
eju
4jwv
Posted: November 10, 2003 at 9:01 AM / IP Logged
I read somewhere that you will need to tap into a hot, when ignition is on wire.  Do you know what the speaker wire color codes are for a 2002 Trailblazer non- bose headunit? I am getting ready to install a 4 channel amp and new speakers. Good luck with your install.  Jeff
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
