cd player in 1992 chevrolet cavalier
jasonstrohl
Posted: November 10, 2003 at 5:44 AM / IP Logged
I am not at all proficient in car stereo intallation, but I have intalled stereos in my cars in the past. I am currently attempting to install a cd player into my 1992 chevrolet cavalier following the guidelines set by the schematics. When I hook up the constant and the switched power to their respective wires, and turn the car on the cd player appears to have power but I can only hear music faintly coming from one of the rear speakers. In addition, the back of the cd player gets hot. I attributed this to poor graounding and even trid to ground the cd player directly to the body of the car, but this does not help. The device has been sitting in a trunk for about a year, so it may be damaged, but I doubt it. Can anyone offer any advice? Thanks.
DYohn
Platinum - Posts: 10,741
Posted: November 10, 2003 at 7:23 AM / IP Logged
I suspect you have the speakers wired incorrectly or they are shorting to ground.  If the power ground was bad the unit would not turn on.  If the head unit is heating up right away, it is being overloaded.  Did you use an adaptor to the factory wiring harness(prefered method)  or did you cut off the factory harness connector?  Are you trying to use the factory OEM speakers?  Did this car have  "premium audio system" or a Bose system?
jasonstrohl
Posted: November 10, 2003 at 8:46 AM / IP Logged
Orginally I was using a harness, but in order to try to correct the problem, I removed the harness to test the wiring. I tested the speakers with a 9 volt battery, and I have them all correcly wired. I am using the factory speakers and the car (until now) had the factory audio system.
DYohn
Posted: November 10, 2003 at 9:26 AM / IP Logged
If you are certain there is no factory amp in the system, and you have tested all the speakers and are sure they are OK, try re-installing the factory radio to make sure the speakrs are OK.  This may be more difficult if you have removed the factory harness connector (which you should never do, in my opinion.)  If it works, then your CD head unit is probably defective.  You could also get a spare speaker and hook it up directly to the new head unit one channel at a time to test the head unit and bypass any possible problems in the factory wiring.
Good luck!
jasonstrohl
Posted: November 10, 2003 at 12:10 PM / IP Logged
thanks for the advice...I'll check it out.
