Fuse how many Amps
flashalexb
Copper - Posts: 62
Posted: November 20, 2003 at 10:52 PM / IP Logged
What size fuse should I use for the Audiobahn A8002T amp? http://www.audio-warehouse.com/web/mdl/A8002T/detail.asp
Its 2x400 watts rms at 2 ohms
mobiletoys2002
Gold - Posts: 1,050
Posted: November 20, 2003 at 11:52 PM / IP Logged
If the amp is running briged at 800 watts you are looking at about 65 amps of current draw if it is running at 200 watts by 2 stereo your draw is about 30 amps so dont go larger tahn the 6maybe a 70 if you brige the amp and if you run stereo at 4 ohms then use a 30 amp fuse or so . It is better to under rate a fuse than to over so use the least value of fuse that does not blow at full volume the values given should be right.
flashalexb
Copper - Posts: 62
Posted: November 21, 2003 at 3:19 PM / IP Logged
But Ive heard that if you use a fuse that is to underrated then it will limit the performance of your subs. Is that true?
bberman1
Gold - Posts: 2,314
Posted: November 21, 2003 at 3:30 PM / IP Logged
To calculate the fuse take the rms 800 divide by voltage 12.8 and you will get the amps 62.5. I would use a 60 amp fuse, which will give you the closest fuse rating. As far as a fuse limiting the performance of your sub it’s not true. The only thing that would happen is you would blow the underrated fuse.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 21, 2003 at 5:36 PM / IP Logged
a 60 amp fuse would be perfect ,and bberman is correct the fuse will only blow and cannot limit performance. it is better to under do a fuse thsn overdue and my original post had a typo dont use the 70 amp use the 60,good luck.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
