RCA Input on stock Fords
EluminusCivic
Posted: December 07, 2003 at 7:59 AM / IP Logged
Wasup people, got some questions. I'm doing some installs for a couple people and just by chance, they're both Ford. A 2000 Ford Ranger XLT Extended Cab and a 2001 Ford Focus Sedan.
Ok, so I'm doing the install. Wire here, pass it through there, splice this, screw that, everything is going just fine. I like to spend a lot more time on hiding everything to make it a nice clean install, so I usually spend about twice as much time on the install. I got a problem though, both these people still have the stock unit. Here's my question:
Can I somehow hookup the proper RCA cabling for the amp to a stock head unit?
Someone else did it before you, so learn. Nothing is impossible. - My dad.
callmeraven
Member - Posts: 17
Posted: December 07, 2003 at 8:56 AM / IP Logged
The stock radio probably won't have RCA jacks so you'll need to use a line output converter. Best Buy or stores like it should stock them for about $14.99 or so.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
