Lightning Audio S4.600 good for Highs?
JustDoIt2
Copper - Posts: 98
Posted: December 23, 2003 at 1:02 PM / IP Logged
HI, IM looking for a good amp for my mid and highs, and i was looking at this amp
60w x2 @ 4 ohms Front Channels
150W x2 @ 4 ohms  Rear Channels.
If you guys this this is not a good amp, which one would you recommend it for the mid and high,
thnak you for your helps!!!
bberman1
Gold - Posts: 2,314
Posted: December 23, 2003 at 1:11 PM / IP Logged
What speakers do you have?
forbidden
Platinum - Posts: 5,354
Posted: December 23, 2003 at 2:43 PM / IP Logged
Exactly what bberman said, I have used this amp on many occasions, it is a good amplifier, you should be quite happy with it.
JustDoIt2
Copper - Posts: 98
Posted: December 23, 2003 at 10:51 PM / IP Logged
OK, I have infinity 5 1/2 component system (rear)
and pioneer 4" component system..(front)
forbidden
Posted: December 23, 2003 at 10:54 PM / IP Logged
This is a good size amplifier, maybe too powerful for the little 4" and 5.25" speakers, but it is a great amp, make sure the gains are turned way down and the crossovers are set correct, it will be easy to drive the small speakers to their limits with this amp.
JustDoIt2
Copper - Posts: 98
Posted: December 23, 2003 at 10:57 PM / IP Logged
oh ok, But It will not hurt because i have to connect it to the crossovers.....
If you which other amp would you get, i want something sound clean and good.
thank you
forbidden
Posted: December 23, 2003 at 11:02 PM / IP Logged
Eclipse EA3422 or PA5422Lightning Audio S4.600 good for Highs? -- posted image.
JustDoIt2
Copper - Posts: 98
Posted: December 23, 2003 at 11:13 PM / IP Logged
ok,  and another brand which one is good
forbidden
Posted: December 23, 2003 at 11:18 PM / IP Logged
Personal preference would be the Eclipse PA5422. It really depends on your budget, not my tastes, you hear different than I do and may like the sound of a Sony (cringe) better than a Lightning, but I hope not. I run an XTANT amp in my MR2, would have gone to Diamond if I could have made them fit, my next choice was Eclipse.
