speaker quality & sound is poor
ByThaBay
Posted: December 26, 2003 at 5:03 AM / IP Logged
I have two JL audio 5" 2 way speakers in my front doors. for some reason, the driver's side one was really quiet today and the quality of the sound was poor.. i know because I isolated the speaker by using the fader controls. when i turnd the head unit up almost all the way, it was as if something had "kicked-in" and the speaker began operating normaly. I have not been able to duplicate this problem. any ideas?
Durwood
Copper - Posts: 126
Posted: December 26, 2003 at 5:20 AM / IP Logged
I've had something similar to that happen, and it turned out that the wires to the speaker were chafing where they passed from the kick-panel area into the door.  Try isolating the speaker with the balance/fader controls like you did before, then open and close the door several times and see if that gives you the "kicking-in" effect.  Either way, I'd check the wire bundle for chafing, both where it leaves the kickpanel area, and where it enters the door.
Scott Gardner
Laur
Copper - Posts: 65
Posted: December 27, 2003 at 6:09 PM / IP Logged
you can try to see if one of the wires is destroyed and pushed to the carbody
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
