2 Comp vrs in Slot port box
lost_logan
Posted: January 07, 2004 at 12:34 PM / IP Logged
ok i have 2 Comp VRs dual 2 Ohm vc they will be wired in series/parrel for a 2 ohm load and im playin on buildin a slot port box any ideas on what size to make it
p.s. they will be goign in a 91 chevy reg cab wit stock 40-60 split seat
the amp is a legacy... i kno no cash for new one tho
lost_logan
Posted: January 07, 2004 at 12:42 PM / IP Logged
there the 10's
mindctrl
Copper - Posts: 114
Posted: January 07, 2004 at 3:48 PM / IP Logged
Well, in the future, just go to the manufacturer's website and look up their product specs... But I already did it for you so theres no point now =P.
Make the box out of 1" MDF, with at least 1.25 cubic feet of airspace in the interior per sub, but no more then 1.75 per sub.  This gives you a little to play around with.  I would suggest going 1.5 cubic feet per sub, giving you a total of 3 cubic feet, so that will give you some space to err.  Make sure you isolate the subs from each other(build a barrier on the inside of the box and seal it with some liquid nails.)
I have no clue what to do for your slotted port, however, since I don't know what the regular port tuning is... Any other questions?
--mindctrl
lost_logan
Posted: January 07, 2004 at 8:08 PM / IP Logged
i kno but there older comp vr's so i was not to sure bout that.
any one kno if u can amke the slot inside the box any size but make the opening a certian size?? and how do i tune it
mindctrl
Copper - Posts: 114
Posted: January 07, 2004 at 10:51 PM / IP Logged
Well you need to find out the specs of your subwoofers before I can help you figure out the port size.  Call Kicker.
--mindctrl
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
