2004 Pontiac Sunfire amp turn on lead?
Liberty03
Member - Posts: 6
Posted: January 28, 2004 at 9:47 PM / IP Logged
I am needing info about what wire to tap for a signal to turn on an amp for an '04 Sunfire.  I don't want to run it off of the head unit b/c of the data bus system...I was told by one installer to use the wire coming from the fuse block from the wipers b/c that was an actual accessory not associated with the computer.  What color is that wire? And are there any other wires that would be safe to tap onto for a turn on lead for an amp?  Thanks a lot!
Liberty03
Member - Posts: 6
Posted: January 29, 2004 at 10:26 AM / IP Logged
Hello?  I'm new to this forum...is the 04 Sunfire the same as an 03?  I just need to know a safe wire to use for a turn on lead for an amp! thanks
corraudio
Member - Posts: 28
Posted: January 29, 2004 at 11:56 AM / IP Logged
i use the Brown wire in the main ignition harness.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
