2002 sunfire, amplifier
I Am
Member - Posts: 34
Posted: February 29, 2004 at 2:14 PM / IP Logged
I am having a problem installing my amp.........how do I  install the inline fuse off the batt when it came it was in a loop with fuse in the middle......do I cut it and attatch it to the power wire......
Bnluis
Silver - Posts: 578
Posted: February 29, 2004 at 2:36 PM / IP Logged
yes cut it attach one side to battery, other side to wire to amp
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
I Am
Member - Posts: 34
Posted: February 29, 2004 at 2:38 PM / IP Logged
ty..... I have one more q about finding a wire to hook up my 12volt amp turn on......wut can I use I am using a stalk deck
forbidden
Platinum - Posts: 5,354
Posted: February 29, 2004 at 4:14 PM / IP Logged
You will need to attach it to the pink wire in the ignition harness. This wire will be found with many other wires (be careful) coming from the ignition tumbler and following down the steering column. It is easily accessable.
