Pioneer AVH-P6500 parking brake!
audioinnovation
Member - Posts: 13
Posted: March 23, 2004 at 2:52 PM / IP Logged
Hi guys, I have purchsed the avh-p6000 from the U.S, uk models dont have this parking brake cable! however my U.S model has this parking brekae cable therefore I am wondering will I need to connect this up?
If I do then  I can only turn it on when car is stationary :-(((( anyone suggest an alternative method? or maybe I dont even need to wire it up to the parking brake at all!
Thanks in advance!
Ravendarat
Platinum - Posts: 2,806
Posted: March 23, 2004 at 2:53 PM / IP Logged
ground the wire for parking brake, then it will work whenever you want it to
audioinnovation
Member - Posts: 13
Posted: March 23, 2004 at 2:57 PM / IP Logged
Hi Ravendarat,
when you say ground the parking brake, the wire from the pioneer harness is green and has a switch on it, the switch then has a ground cable running from it?, the instructions tell me to connect the green wire to the parking brake cable with a scotch connector and connect the ground cable from the switch to the chassis!
Ravendarat
Posted: March 23, 2004 at 3:48 PM / IP Logged
If you do that then it will only work with the ebrake on. If you just ground the green wire than it will work whenever you want it to
audioinnovation
Member - Posts: 13
Posted: March 23, 2004 at 4:52 PM / IP Logged
aha I understand now :-) I will give that a go!
Many thanks!
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
