amp suggestions?
gumby_55
Member - Posts: 38
Posted: March 26, 2004 at 10:33 PM / IP Logged
Hi, I'm getting two rockford fosgate HX2 15's and I was wondering if anybody had any suggestions of what amp I should get and how to wire it. Each sub is dual 4 ohm voice coil,  600 watts RMS. I would prefer the amp to be a mono amp. Thanks in advance for any replies.
forbidden
Platinum - Posts: 5,354
Posted: March 26, 2004 at 11:02 PM / IP Logged
Concept CA1210 would do quite nice.
aggie altima
Silver - Posts: 298
Posted: March 27, 2004 at 5:14 AM / IP Logged
Since you have 2 dual 4ohm speakers, your only options for a mono amp are 4 ohm or 1 ohm. Since an amp that puts out 1200 watts RMS at 4 ohms will be extremely expensive, you will probably want to run an amp that is 1 ohm stable. A good bang for the buck amp is the JBL Powervalve BP1200.1, which puts out 1200 watts RMS at 1 or 2 ohms, which would be a perfect match for your subs. I would search for other alternatives, but I have dial-up right now, boo.
Jon
Don't like rockford subs? Then don't look at my car =)
Clean Install
Silver - Posts: 446
Posted: March 27, 2004 at 6:44 AM / IP Logged
I agree with the above the jbl amp is a great amp...
If we learn from each success and
each failure, then we can improve ourselves
superstreet786
Silver - Posts: 339
Posted: March 31, 2004 at 12:28 PM / IP Logged
Get a rockford amp and use them together or even a Lightning Audio amp... i use them and theyre great as well
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
forbidden
Posted: March 31, 2004 at 12:54 PM / IP Logged
The Lightning Storm mono class D amp is great, but the new Concept amps with the better warranty still get my vote. Wire the subs up in an all parallel configuration for a 1 ohm mono load.
superstreet786
Silver - Posts: 339
Posted: March 31, 2004 at 5:44 PM / IP Logged
I do love the price of Lightning... cheap dependable equipment.  The only good Lightning series are Storm and Strike though.  Bolt sucks BAD
