Lcd & Dvd Install Question
Eliteviper7782
Posted: March 28, 2004 at 9:55 PM / IP Logged
Ok i have a pioneer premier headunit in my car, I just purchased an in dash dvd player for my car, and a 6" tft active matrix stand monitor. the dvd player has rca outs on it so i am going to run the audio to the aux input of the deck and i am going to run the video to the monitor. How do i go about powering the monitor and the dvd player?? Should i run a power wire from the 12v constant?, or from the ignition?, under the steering wheel, and branch it out to both and just have a 30 amp fuse before the branch>??Or should i just t-tap into the power that powers my deck>?I am going to t-tap into the memory wire for my deck but should i t-tap the power to or just run a different wire with a fuse breaker?? Any other ideas are greatly appreciated as well.
Thanks For The Help,
Brian
raydawg357
Silver - Posts: 769
Posted: March 29, 2004 at 8:11 AM / IP Logged
I wouldn't recommend using t-taps at all, they tend to move around and loose connections.  I would run it all from your head unit.  This way once your HU is on you have power to your screen and dvd player.  Each component should have it 's on inline fuse so there isn't a need to change out any fuses.  You can also use relays to turn these extras if you like.
Do it right the first time
Eliteviper7782
Posted: March 29, 2004 at 9:29 AM / IP Logged
Wont this draw to much power from that one wire going to my deck?? How would i bring those 3 wires together?? a butt connector?? butt connector the line going to the deck, and put all 3 wires into the other end of the butt connector??
Thanks,
Brian
raydawg357
Silver - Posts: 769
Posted: March 29, 2004 at 9:49 AM / IP Logged
No, none of your accy pull that much current.  A butt connector will do fine.
raydawg357
Silver - Posts: 769
Posted: March 29, 2004 at 9:50 AM / IP Logged
No, none of your units draw that much current.  A butt connector will do fine
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
