Grounded my remote wire, can it be fixed?
john11775
Posted: March 31, 2004 at 8:53 PM / IP Logged
When removing my amp from my car I grounded my wire with my remote wire and my radio stopped working how can I fix this? Also, bare with me I am new to this group and have very limited knowledge.
john
Clean Install
Silver - Posts: 446
Posted: March 31, 2004 at 9:02 PM / IP Logged
If i read this correctly, you have the remote wire and the ground connected?
If we learn from each success and
each failure, then we can improve ourselves
john11775
Posted: March 31, 2004 at 9:09 PM / IP Logged
Yes, I sure did. It sparked and my radio went off.
john
john11775
Posted: March 31, 2004 at 9:12 PM / IP Logged
Yes I sure did it sparked and my radio went out. Did I blow a fuse?
john
Clean Install
Silver - Posts: 446
Posted: March 31, 2004 at 9:14 PM / IP Logged
Ok, have you checked the fuses yet?
Clean Install
Silver - Posts: 446
Posted: March 31, 2004 at 9:28 PM / IP Logged
there will be normally a fuse on the back of the head unit, also check the under the dash and under the hood...
Alpine Guy
Platinum - Posts: 2,478
Posted: March 31, 2004 at 9:39 PM / IP Logged
y would you ever work on something when its on?
Clean Install
Silver - Posts: 446
Posted: March 31, 2004 at 9:47 PM / IP Logged
Full PM ? jason? Grounded my remote wire, can it be fixed? -- posted image.
stevdart
Platinum - Posts: 5,816
Disconnect the ground from the battery before you poke around.
superstreet786
Silver - Posts: 339
Posted: March 31, 2004 at 10:03 PM / IP Logged
Every time you do anything turn off everything and take out all amp fuses... your probably lucky and just blew a fuse though
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
