sound dampening
bitis
Posted: April 04, 2004 at 9:25 PM / IP Logged
i was wondering if anyone knows of any cheap supplters of dampening sheets also a friend of mine said he has heard of people applying those spray on bedliners and rubberized undercoating instead of sheets.if so has anyone had any sucess with the spray ons any reply would be appreciated
bitis
Chad7n7
Silver - Posts: 408
Posted: April 05, 2004 at 2:22 AM / IP Logged
Yes, our shop carries CAE dampening materials, there are several different forms, but the easiest way we have found for inside doors is a spray from CAE. All it really consists of is the same as undercoating, it does have a little different texture, but if you are looking for a cheap suppliment, it will be sufficient. However, if you are wanting to completely dampen your doors, you would have to use a heat shrink type door skin to replace the factory plastic skin. Hope this is helpful.
sam1
Copper - Posts: 151
Posted: April 05, 2004 at 3:25 PM / IP Logged
check out edesignaudio.com as well.  they have sheets and also paint-on dampener for relatively cheap.
audiobahn10s
Member - Posts: 16
Posted: April 05, 2004 at 3:38 PM / IP Logged
ice guard for roofing i guess works good,
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
