2004 Toyota 4Runner
nava94
Silver - Posts: 296
Posted: April 05, 2004 at 10:31 PM / IP Logged
Hey guys need wiring diagram on the factory radio plug for the  Toyota 4Runner Limited with JBL Synthesis System. Vehicle has 2 front speakers w/tweeters, center speaker, rear door speakers, sub, & 2 tweeters in the rear d-pillars. Car does not have Nav. System, factory radio with tape & cd.Thanks.
Chad7n7
Silver - Posts: 408
Posted: April 06, 2004 at 1:04 AM / IP Logged
I think this might be a little hard to get your hands on, although I may be wrong, someone may have it, but I have had the same problem last week with one of these, had to go to the dealership to get it, and it is one heck of a run around, when you get to pulling it down, you will see what I'm talking about. There are about 10 different harnesses into one central to the factory amp. But I'll send the diagram I have tomorrow, I have to get it from the shop.
lagatbezan
Copper - Posts: 117
Posted: April 06, 2004 at 1:05 AM / IP Logged
i believe you can get a wire harness for this car.  Pripheral lists one for the premier system; part number: BHA8113 for the 4Runner limited.  This should be the harness but not 100% sure. let me know if it the right one.
lagatbezan
Copper - Posts: 117
Posted: April 06, 2004 at 1:06 AM / IP Logged
i believe you can get a wire harness for this car.  Pripheral lists one for the premier system; part number: BHA8113 for the 4Runner limited.  This should be the harness but not 100% sure. let me know if its the right one.
nava94
Silver - Posts: 296
Posted: April 06, 2004 at 9:56 PM / IP Logged
Kool I'll appreciate it chad.Lagatbezan I'll look into that harness, thanks. I spoke to a Technician at Toyota he said the whole wiring schematic on the audio system just loops around from one front amp to the rear amp not counting the optional rear seat controls.
