Smell
flashalex
Member - Posts: 32
Posted: April 07, 2004 at 10:56 PM / IP Logged
When my subwoofers play for awhile there is like a metally smell that I think comes from the amplfier. Its not a very strong smell but if u put ur head in my truck you can smell it. Is this smell bad or normal and what causes it.
DYohn
Moderator - Posts: 10,741
Posted: April 07, 2004 at 11:16 PM / IP Logged
Sounds like you are smelling heat build up.  Your power amps and your subs can generate large amounts of heat so there must be sufficient air flow to allow them to cool.  Some sub enclosures that are either over-stuffed or improperly stuffed can create smells from the subs burning the polyfill inside the enclosure.  This is especially noticable in high powered ported systems.
flashalex
Member - Posts: 32
Posted: April 08, 2004 at 10:18 AM / IP Logged
Yea I do have a Bandpass box so that may be it.
Alpine Guy
Platinum - Posts: 2,478
Posted: April 08, 2004 at 7:06 PM / IP Logged
if the box is brand new then its probably just the dust burning off the voice coils.
flashalex
Member - Posts: 32
Posted: April 08, 2004 at 7:32 PM / IP Logged
Well it may be coming from the amp because if i smell the vent where the amp is cooled I can smell it there
customsuburb
Gold - Posts: 1,813
Posted: April 08, 2004 at 7:39 PM / IP Logged
Like forbiddne would say "sounds like sss (smelly speaker syndrom). Are your gains set right on ur amp.
flashalex
Member - Posts: 32
Posted: April 08, 2004 at 11:17 PM / IP Logged
Well it aint that much of a problem because because I cant smell it in my car just my trunk but even there its very faint.
cmh
Member - Posts: 20
Posted: April 09, 2004 at 12:23 AM / IP Logged
I have the same problem and let me tell you that I fixed the problem by not blasting away all of my hearing and suggest that you do the same. IE- I am powering 2 Volfenhag zx-412's at a load of 4 ohms total with a Koiiler 1500, 1500 watts peak into 4 ohms a little over 1000 continuous and that produces over 120 DB in the cab with a tuned ported 40 hz box, anyway it was starting to smell up really good and I was expieriencing constant headaches so just by turning it all down has helped both problems alot. Remember that even though you "can" doesn't mean you should listen at killer volumes at all time. Don't mean to preach but just trying to share a similar problem with other reprecussions.
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
