Tweeter install help
metalgear
Member - Posts: 6
Posted: April 08, 2004 at 7:22 PM / IP Logged
Just bought a pair of tweeters and I am planning on hooking them up using the door speakers as well ( just low range ) while putting the tweeters on the dash for a little better sound. They are cap filtered with +- in and +- out of little filter box. How would I go about wiring these tweeters up? Should I just wire them parralel with the existing speakers? (ex. cutting wire to other speaker and making a 3 way splice in the dash. )
customsuburb
Gold - Posts: 1,813
Posted: April 08, 2004 at 7:47 PM / IP Logged
Wiring them in parallel should be fine. Are you sure you want to put them on your dash? You might want to try putting a long wire on them and listen to them mounted on different locations up front (like around your door panel and different places on your dash).
metalgear
Member - Posts: 6
Posted: April 08, 2004 at 7:59 PM / IP Logged
Yeah, My basic idea was to use the angled mounts they came with, and try a few different places first. Most likely will put them on either far side of the dash ( back toward the windshield ).
metalgear
Member - Posts: 6
Posted: April 08, 2004 at 8:48 PM / IP Logged
I spliced the wires behind the deck and connected one of the tweeters a few minutes ago, It cuts off the low on the other speaker.. /shrug/ so in essence i only have the one tweeter instead of a tweeter and a low.
customsuburb
Gold - Posts: 1,813
Posted: April 08, 2004 at 9:34 PM / IP Logged
hmm.. are all your connections secure? It might be too low of impedance for your head-unit to handle. Is it an aftermarket or stock one?
metalgear
Member - Posts: 6
Posted: April 09, 2004 at 11:27 AM / IP Logged
Head unit is a pioneer 8400
speakers are run of the mill pioneer 2 way 200 watts
tweeters are power acoustik NEO-30x
All connections are secure.
metalgear
Member - Posts: 6
Posted: April 09, 2004 at 11:28 AM / IP Logged
my cars wiring map says that both front speakers have a common (-) wire off the deck, Does this sound right ?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
