enclosure fill
pimpneon03
Member - Posts: 10
Posted: April 10, 2004 at 11:54 PM / IP Logged
whats a good material to use as a fill for a sub enclosure and where can i get it?
stevdart
Platinum - Posts: 5,816
Posted: April 11, 2004 at 12:02 AM / IP Logged
Try this, it takes about half as much as regular polyfill (which is found at your local crafts store).  This cost more, so it must be better!  http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-317
Clean Install
Silver - Posts: 446
Posted: April 11, 2004 at 12:03 AM / IP Logged
polyfil
a local shop should have some or you can maybe pick some up at ?walmart? or online at some place like partsexpress
I think its about 10.00 bucks or so...
If we learn from each success and
each failure, then we can improve ourselves
pimpneon03
Member - Posts: 10
Posted: April 11, 2004 at 12:16 AM / IP Logged
is pillow stuffing a good fill im not sure what material it is but will it work?
stevdart
Posted: April 11, 2004 at 12:21 AM / IP Logged
The bag will be labelled "polyester fiberfil".  Don't use feathers.
