2 ohm Wiring Confusion
GasGuzz
Member - Posts: 25
Posted: April 12, 2004 at 1:49 PM / IP Logged
http://www.rockfordfosgate.com/rftech/wiringwizard/2_4ohmSVC_2ohm.gif
Well, the amp has 4 speaker terminals/outputs (+/- right and left channels).
Dumb question:
What is the 2 ohm connection, is the (+) and (-) from one channel (either right or left)?
Or, is the (+) from the right-channel and the (-) from the left-channel?
Thanks.
GasGuzz
Member - Posts: 25
Posted: April 12, 2004 at 1:52 PM / IP Logged
Correction: That would be the UN-bridged outputs.
DYohn
Platinum - Posts: 10,741
Posted: April 12, 2004 at 2:40 PM / IP Logged
There is no "2-ohm connection" on a modern amp.  The amp has outputs and can handle whatever impedence load you put on it up to its ratings.  Which amp do you have?
GasGuzz
Member - Posts: 25
Posted: April 12, 2004 at 2:52 PM / IP Logged
Thanks, DY.
Yes, agreed (Alpine MRV-T320 80W x 2). I understand the 2 ohm load, in relation to amp/speaker config.
I know you have the answer.
http://www.crutchfield.com/S-sweod4KRtEM/cgi-bin/ProdView.asp?s=0&cc=01&g=110&id=morephotos&pi=6&i=500MRVT320&display=XL#morephotos
Where is the hookup?
GasGuzz
Member - Posts: 25
Posted: April 12, 2004 at 3:36 PM / IP Logged
By the way, I'm looking at this to run the rear CH 2-way coaxials.
customsuburb
Gold - Posts: 1,813
Posted: April 12, 2004 at 4:18 PM / IP Logged
what is your question?
DYohn
Posted: April 12, 2004 at 4:55 PM / IP Logged
I'm not sure what you are asking, but the Alpine MRV-T320 is a stereo amp.  It has two outputs, a positive and a negative for each of its 2-channels.  Hook your left coax to one output set (+ to + and - to -) and the right coax to the other.  It will deliver up to 80 watts per channel into a 4-ohm load (most likely what your coaxials are.)
GasGuzz
Member - Posts: 25
Posted: April 12, 2004 at 5:00 PM / IP Logged
Yah, its' clear.
I looked at it again - and overanalyzed.
Duh!
Thanks again.
