2004 4Runner OEM Head Unit Swap
GVales
Posted: April 29, 2004 at 2:08 AM / IP Logged
I have a 2004 4Runner with the basic (non JBL) CD/Cass/AM/FM Stereo. I have an opportunity to by the JBL in dash 6 disk head OEM head unit for the same model year truck. Can I just unplug the old head unit and snap in the new one and have it function correctly?
Sweekster
Silver - Posts: 481
Posted: April 29, 2004 at 10:54 AM / IP Logged
That might not work. The JBL unit probably needs an external amp or amps and also I think it uses specific speakers as well, which you may also need. Something like that usually isn't an easy swap because of all the external equipment involved. The radio may plug right in and turn on but you probably wouldn't hear any sound. I suggest contacting your local toyota dealer and have them cross reference the two radios (get the model numbers and part numbers of both) to see if they are interchangable.
Duane...
If you think you're confused, imagine how you feel.   2004 4Runner OEM Head Unit Swap -- posted image.
Chad7n7
Silver - Posts: 408
Posted: May 02, 2004 at 1:20 AM / IP Logged
good call^^^^^^(going to dealersip to cross reference)
Thursday, February 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
