kenwood kac 648s
loonytu
Member - Posts: 13
Posted: May 01, 2004 at 11:57 PM / IP Logged
i want to know how to hook up this amp with a second sub amp in the line out of the 648s amp. i do not understand in the manual it shows you a picture of four speakers and a sub using a different amp hooked in the line out
DYohn
Platinum - Posts: 10,741
Posted: May 02, 2004 at 11:17 AM / IP Logged
That amplifier includes a set of line level (RCA) outputs.  These will pass through the signal connected to channels 3 and 4 of the 648 to a second amplifier.  Simply connect a stereo RCA patch cable from the output of the 648 to the input of your sub amp.
loonytu
Member - Posts: 13
Posted: May 02, 2004 at 2:44 PM / IP Logged
can i use any amp for the subs
forbidden
Platinum - Posts: 5,354
Posted: May 02, 2004 at 2:53 PM / IP Logged
Any amp you want, except Sony, friends don't let friends buy Sony. The Kenmore amp does not care what is hooked to the pass through rca outputs.
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
