3 dual 4ohm subs
MikeHusain
Copper - Posts: 139
Posted: May 04, 2004 at 5:21 PM / IP Logged
I have 3 dual 4ohm subs and I wanted some feedback on bridging them.  I was planning on bridging each sub in series to get 8ohms and then all 3 subs in parallel to get a 2.666 ohm load.  I know that i will need an amp that is stable to a 2 ohm mono output.  Will subs sound better if you match exactly what the amp is stable to?  I will be over 0.6666 ohms what the amp can put out, so i guess that would be better for the amp so that it will run a little cooler than an exact 2 ohm load.  I think amps run hotter when you go below the minimum impedence and will probably clip and eventually burn out.  IS that true?  I also heard that most 2 ohm mono  amps can handle a 1 ohm load but wont mention it on the specs because there is a chance that it will burn out somewhere down the road.  Thanks .......
kickerstang
Copper - Posts: 180
Posted: May 04, 2004 at 5:28 PM / IP Logged
it is true that amps run hotter when you go below the rated impedance and that's because you are overworking them to the point of possibly burning up your amp.  if you run an amp that is 2 ohm stable at 2.66 you just won't achieve maximum power, but you won't have to worry about frying your amp either.
what!?!?! you want some??
Ravendarat
Platinum - Posts: 2,806
Posted: May 04, 2004 at 5:48 PM / IP Logged
There arent any amps out there that I know of that are 2.666 ohms stable and not 2 ohm stable. Its kinda erralivent because the amp running at 2.66 ohms is gonna be fine. Kickerstang is right that you wont be running the amp to full potential but running it at 2.66 ohms is gonna be perfectly fine and keep the amp running kooler.
forbidden
Platinum - Posts: 5,354
Posted: May 04, 2004 at 6:47 PM / IP Logged
Yup, just find yourself a good amp that is stable to either 1 ohm or 2 ohm mono and gives you the output power you need to power the subs.
thapimpfromchi
Silver - Posts: 616
Posted: May 04, 2004 at 9:43 PM / IP Logged
arent there amps stable down to .5 ohms?.....
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Ravendarat
Posted: May 04, 2004 at 9:57 PM / IP Logged
ya but you dont need one that is, and if the amp is stable that low than the power output at 2.6 ohms would probally be insufficant
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
