amp over heating
quinny
Member - Posts: 12
Posted: May 05, 2004 at 1:48 AM / IP Logged
brand new platinum digital 1200 monblock power amp over heat in seconds has anyone go any idears?
i followed the instruction manual for the wireing.
quinny
Member - Posts: 12
Posted: May 05, 2004 at 1:49 AM / IP Logged
it is also blowing main power fuse
smurfsjeep
Member - Posts: 14
Posted: May 05, 2004 at 1:59 AM / IP Logged
did u happen to check yor ground..???
quinny
Member - Posts: 12
Posted: May 05, 2004 at 2:06 AM / IP Logged
yes ground wire heat up too
smurfsjeep
Member - Posts: 14
Posted: May 05, 2004 at 2:09 AM / IP Logged
where do u have the ground connected to??? and what do u have  running in your car right now???
smurfsjeep
Member - Posts: 14
Posted: May 05, 2004 at 2:24 AM / IP Logged
i also tried the white wire on the factory amp but got no sound when i did that.. and if i did get sound it was late and distorted...
quinny
Member - Posts: 12
Posted: May 05, 2004 at 2:26 AM / IP Logged
it is connected to bolt in floor of car.
only 1 12 inch alpine sub for now would like it to run 1 12's
quinny
Member - Posts: 12
Posted: May 05, 2004 at 2:27 AM / IP Logged
i mean two 12 inch subs
smurfsjeep
Member - Posts: 14
u r using the seat belt right???? basic installation always use the seat belt screw.. greatest ground in the car direct to the chasis
quinny
Member - Posts: 12
Posted: May 05, 2004 at 2:44 AM / IP Logged
no it is not it is using tie down bolt that go's through in to chasis
Wednesday, October 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
