Rear soundstage
sunshine
Member - Posts: 35
Posted: May 06, 2004 at 2:52 PM / IP Logged
Hi,
I am trying to upgrade the rear soundstage in my hatchback.  In the front I currently have Boston RC620's, which are the 6.5 Rally components.  They are getting power from an old apline giving 35x4 rms.  However, that amp will be upgraded to a RF 600a4 that gives 70x4 at 4 ohms.  In the back I am installing an Eclipse aluminum 10" getting 400watts.
Right now, the back speakers in the rear shock towers are little 4" Kappa co-ax's.  I am not very happy with the soundstaging inthe car right now.  Since I want to get new speakers for the back, I figured I'd ask what will work best.
So the question is:  what should I put in the shock towers for optimal soundstaging?  Some of the older posts have recomended to not even have rear speakers if your going for SQ.  so I suppose I can bridge the apline, and drive solely the Bostonst up front with more power.
Any suggestions?
1991 Mazda Rx-7
Alpine HU w/iPod adapter
PG 600.2Ti, Alpine 35x4
Optima Yellow
DYohn
Moderator - Posts: 10,741
Posted: May 06, 2004 at 3:23 PM / IP Logged
Actually if you are going for SQ and worried about soundstaging, I would recomend you do NOT purchase the RF amplifier, and if you do use it, certainly do not bridge it into your comps.  Get a nice clean stereo amp at 100 to 200 watts per channel for those nice Boston components.  Listen to amps from Eclipse, Nakamichi, McIntosh, Zapco etc. and get the best you can afford for your front mains.  Position your tweeters properly to create the front sound stage.  Cross the set over at around 70Hz and your sub at the same.  If you need rear fill (which you may not at all) you could certainly use your infinity's and your 35 watt amp crossed over at about 300Hz.  If you want to replace the Infinity's, the Boston RX47 would match the timbre of the front set.
sunshine
Member - Posts: 35
Posted: May 06, 2004 at 3:50 PM / IP Logged
No, I was not going to bridge the RF.  I was only suggesting bridging the Alpine for the interim period.  I love the Eclipse amps.  so maybe if I can find a good deal, I will pick of them up instead.  I just wanted the RF so my amps can match.
1991 Mazda Rx-7
Optima Yellow
DYohn
Posted: May 06, 2004 at 4:33 PM / IP Logged
For SQ, it is much more imporntant that your speakers match (sonicly, not appearance) than the amps.
forbidden
Platinum - Posts: 5,354
Posted: May 06, 2004 at 6:40 PM / IP Logged
I totally agree, could not have said it better.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
