Buy an amp to overpower subs?
chevyman26
Copper - Posts: 227
Posted: May 11, 2004 at 4:31 PM / IP Logged
  O.K., I read in a Car Audio & Electronics that you should buy your amp at least a couple hundred watts bigger than what your subs are rated for so that the subs are being driven well within the amps "clean" capabilities. Does this sound right, and if so how would you set your levels so as not to fry the sub? For example, I have 2 SVC subs that handle 500W ea. I want to buy an amp that is rated at 1400W ( all RMS, of course.) Am I playing with fire here?
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
kgerry
Platinum - Posts: 3,455
Posted: May 11, 2004 at 4:39 PM / IP Logged
i have always overpowered my own systems and i've never blown up anything ever.... you can turn it up and still be using clean power...just use your ears as a benchmark...  distortion ( the amp clipping ) will fry a speaker far more quickly than an excess of clean power.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Mrhunter
Copper - Posts: 86
Posted: May 11, 2004 at 4:50 PM / IP Logged
What does clipping mean?
chevyman26
Copper - Posts: 227
Posted: May 11, 2004 at 5:08 PM / IP Logged
DYohn wrote:
Clipping is distortion that occurs when an amplifier is being pushed beyond it's usable limits.  It is called clipping because on an oscilloscope you can see the waveform tops being "clipped" off and flattened out.  Trained ears can her it when it begins, and most anyone can hear it when it's severe.  Lower quality amplifiers (and especially head unit buiilt-in amplifiers) tend to go into clipping at the RMS output limit.
Clipping can destroy a speaker, and in very severe cases can destroy an amp.
chevyman26
Copper - Posts: 227
Posted: May 11, 2004 at 5:12 PM / IP Logged
Is there a way to tell by ear if you are pushing too much power to the subs, even if it it is clean power? It shouldn't be clipping, but will there be any indication?
stevdart
Platinum - Posts: 5,816
Posted: May 11, 2004 at 5:59 PM / IP Logged
I am guessing that the opinion you read and referred to in your original post was from a participant in a forum, and not a highly qualified audio engineer.  I am just a forum participant too, and certainly no engineer of any kind, but I know that buying an amp that is one to two hundred watts more powerful than the speaker can handle is just plain foolish.  You better have some extra speakers on hand to replace the ones you ruin.
It seems like it is the common mistake of not understanding how to adjust the amp sensitivity (using the gain control) with the volume on the head unit.  An amp that will produce 1000 watts is going to make that much power no matter where the gain control is set.  Let's say you bought that advice and decided to overpower your speakers.  As you turn the volume up, you won't get to that 'critical stop' point where distortion begins and you know to back off because you're at the limit.  Too much power is fed to the speakers and they over-excurt.  Too much heat.  And some other things I don't know about.  Goodbye.
However, if the amp and speaker RMS are matched, and the amp input sensitivity is set to match the output of the head unit (see setting gain), as you turn the volume up you will reach that 'critical stop' point because the distortion will sound terrible and you'll turn it back down.  That is, if you are pushing it past the point on the dial you know not to go past.
This can be argued, and is, either way.  Because truth is both will destroy a speaker.  But one way makes sense and the other way doesn't.
To answer your Question " is there a way to tell by ear...", the answer is sometimes and sometimes not.  Maybe and maybe not.  Don't overpower your speakers so you don't have to find out for yourself.
chevyman26
Copper - Posts: 227
Posted: May 11, 2004 at 6:06 PM / IP Logged
The guy that wrote the article was Steve Brown from Alpine USA. He designs and builds alpines show cars.
pureRF
Silver - Posts: 619
Posted: May 11, 2004 at 6:07 PM / IP Logged
No you shouldnt overpower your subs. You should buy a good enough amp that will run its true RMS which should match the subs RMS
dream it, build it, fiberglass it
stevdart
Posted: May 11, 2004 at 6:17 PM / IP Logged
I went to high school with a Steve Brown.  He was a real bullsh!!ter.  I'm going to search for his article.
Mrhunter
Copper - Posts: 86
Posted: May 11, 2004 at 6:18 PM / IP Logged
A little bit of a common name isnt it?
Page of 3
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
