2000 Ford Focus SE 4 Gauge Power
dogmaiwli
Posted: May 31, 2004 at 2:44 PM / IP Logged
Trying to find a place in the firewall to run it through to the back of the car without drilling holes, can't find anything, Can anyone reccomend a location, or will I have to go under outside, and drill back in or just drill through the fire wall to begin with?
Any recommendations are Greatly Appreciated, Diagrams are even better :)
stevdart
Platinum - Posts: 5,816
Posted: May 31, 2004 at 8:43 PM / IP Logged
Don't go outside of the car.  Keep it thru the firewall.  Disconnect battery neg. terminal while you're probing at the firewall.  Use something like a coat hanger, wrap the end well with electrical tape so it doesn't cut into anything.  You may want to raise the front end up on jackstands and look at the firewall from the bottom engine side to get an idea of where to go through.  If you find any bare places, locate the area from the passenger side and pull carpet/pad out of the way to drill.  First hole needs only be big enough for the probe.  If you see the hanger emerge on the other side, redrill to specific grommet size, wrap power wire onto probe, and push through.  Place grommet over the wire and leave it loose, then secure into hole after complete install of wire.
stingercaraudio
Member - Posts: 21
Posted: May 31, 2004 at 10:16 PM / IP Logged
drivers side, about 10 inches above brake pedal. isn't there a spot there?? I thought there was.. if not then do what stevdart said.
mobile1
Silver - Posts: 479
Posted: June 01, 2004 at 12:08 AM / IP Logged
Its it a manual or auto. transmission?? if its auto you should be able to drill through the firewall where the clutch normally goes.
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
