how have you removed window cranks
Ketel22
Silver - Posts: 976
Posted: June 05, 2004 at 10:52 PM / IP Logged
im currently working on a 96' dodge neon and i can't figure out the window cranks, i can't find any pins or screws or anything that is holding it on. any help would be appreciated as ofnow....
Quad L Handyman services
silversi17
Member - Posts: 25
Posted: June 05, 2004 at 11:29 PM / IP Logged
you need a special window crank removal tool.  There is a little spring ring inside that holds it on.  You should be able to get that tool from your local auto parts store.
auex
Platinum - Posts: 5,041
Posted: June 06, 2004 at 3:12 AM / IP Logged
Torx bit in the center of the handle. Pop the front of the handle off at the point where the handle meets the door to expose the screw.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mikedawg
Copper - Posts: 142
Posted: June 06, 2004 at 10:34 AM / IP Logged
i gotta 96 neon too man. all you gotta do is grab the crank and pull it towards you. .then with a set of needle nose pliers, pull the retaining pin off. its a "U" shaped piece of metal right between the crank and the door panel. if you got anymore questions about neons, im your man. check out mine sometime. http://www.rankmyride.com/?page=cars/view&CID=3780
always looking for new info and willing to give it
