installing viewing window
insanity44
Member - Posts: 8
Posted: June 08, 2004 at 12:08 AM / IP Logged
ok guys...i am wanting to put a viewing window on my box. i want to know the best way to have a plexiglass viewing window on it.. does it matter how thick the plexiglass is?and how should i put it on the box and how should it be secured
Ketel22
Silver - Posts: 976
Posted: June 08, 2004 at 12:45 AM / IP Logged
you need to cut and router the edges of the cut to accomidate the window. i would suggest at least a 3/8" plexi most likely you will need thicker depending on the sub. you also need to seal the window when you put it on with sealant and screws about ever 1.5".
Quad L Handyman services
