4 ohms OR 2 ohms?
onsatmex5
Copper - Posts: 52
Posted: June 21, 2004 at 7:41 PM / IP Logged
I am installing 2, Dual Voice Coil Solobaric L7's,4 ohms subs. What is the difference if I run them at 4 ohms or at 2 ohms? Is one better than the other? They will be running of a 600.1 kicker amp.
unc2003
Member - Posts: 10
Posted: June 21, 2004 at 9:51 PM / IP Logged
Well, with 2 Dual 4 OHM Subs, 2 OHMS is not an option.  It's either gonna be 4 or 1 OHM.
Before you judge someone, you should first walk a mile in their shoes. Because then your a mile away, and you have their shoes.
jeffchilcott
Platinum - Posts: 2,483
Posted: June 21, 2004 at 9:59 PM / IP Logged
Actually you could run it at 8 which would be pointless, 4 which you could bridge on the amp, you best option or 1 which if you bridge this on the amp it would not hold would go into protection or fry,    the 600.1 is kinda a small amp to be pushing 2 l7's in my advice as well
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
onsatmex5
Copper - Posts: 52
Posted: June 21, 2004 at 10:14 PM / IP Logged
If I get A 1200.1 amp and run them @ 1ohm will my 140amp alternator in my car handle the amp? The subs are 10 inch L7's rated at 600 watts each.
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
