HU help needed with 03 Altima
charlie101_1999
Member - Posts: 40
Posted: July 12, 2004 at 5:08 PM / IP Logged
If any one can help... I have a 03 Altima with out the Bose. I tried hooking up my HU using the Scoshe kit and I couldn't get the HU and hole to line up. Theirs two sets of holes and one in the middle on the reciver bracket but none of them worked. Please help!
raydawg357
Silver - Posts: 769
Posted: July 13, 2004 at 7:41 AM / IP Logged
I have an 03 Altima and didn't run into this problem.  Are you sure you're using the correct kit?
Do it right the first time
Alpine Guy
Platinum - Posts: 2,478
Posted: July 13, 2004 at 12:40 PM / IP Logged
can you snap a picture of your problem?
raydawg357
Silver - Posts: 769
Posted: July 13, 2004 at 12:48 PM / IP Logged
charlie101_1999
Member - Posts: 40
Posted: July 13, 2004 at 3:09 PM / IP Logged
This is the kit I have:
http://www.scosche.com/scosche/installation/kits/NN1496.asp[/URL]
charlie101_1999
Member - Posts: 40
Posted: July 13, 2004 at 3:10 PM / IP Logged
raydawg357
Silver - Posts: 769
Posted: July 13, 2004 at 3:13 PM / IP Logged
That's the correct kit.  Which holes are you refering too?
kgerry
Platinum - Posts: 3,455
Posted: July 13, 2004 at 3:22 PM / IP Logged
are you trying to ISO mount this or with the sleeve?   if with the sleeve you dont need to line up any screws on the chassis of the radio.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
charlie101_1999
Member - Posts: 40
Posted: July 13, 2004 at 8:09 PM / IP Logged
I'm trying to use the two side brackets screwed into the side of the deck. I'm not useing the sleeve, it won't fit into the trim. The two side brackets have five holes each. Two on top two on bottom with one in the midle. I tried all the holes and no matter what, the deck won't line up with the hole of the trim.
Drey
Member - Posts: 35
Posted: July 13, 2004 at 10:18 PM / IP Logged
maybe you have it upside down :)
Saturday, August 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
