Sub + Amp Decision
klutch
Member - Posts: 11
Posted: July 16, 2004 at 12:36 AM / IP Logged
I'm kinda new to the whole car audio thing, doing it myself anyway. I was wondering if the Phoenix Gold Octane-R 12D ( http://www.cardomain.com/item/PHOR12D ) would work ok with the Kenwood KAC-X521 amp ( http://www.crutchfield.com/S-9FCfVtr7M42/cgi-bin/ProdView.asp?i=113KACX521&search=KAC%2DX521 ) and if they are fine what would be the best way to wire them up? also if anyway has the Octane-R 12D please let me know if you are satisfied with them.
klutch
Member - Posts: 11
Posted: July 16, 2004 at 12:59 AM / IP Logged
Or do you guys think the Kenwood KFC W3009  would be a better choice?
stevdart
Platinum - Posts: 5,816
Posted: July 16, 2004 at 5:24 PM / IP Logged
If you are planning on using two subs, you can use the type of amp you referred to.  When the sub is a 4 ohm DVC, it will be either a 2 ohm or a 8 ohm sub when the coils are wired.  Two combined would give the amp a 4 ohm load.  If the plans are to use one sub, look at class D mono amps to power it, because they (check the model) can handle the 2 ohm load.  Here is a wiring wizard.
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
