enclosure design in a limited space
beady
Copper - Posts: 65
Posted: August 13, 2004 at 11:45 AM / IP Logged
I've got a 300ZX and have had sealed boxes in it previously.  When fired up I got a lot of hatch rattle.  I ended up making a downward firing box on small legs and that helped, but it got stolen.
I'm wanting to build a ported enclosure(s) for the Z.  I don't want to fire the driver and ports up as I had bad experiences with that as stated above.
Please discuss advantages/disadvantages of firing the driver and ports FORWARD, REARWARD, and the driver firing into one corner of the hatch and the port(s) into the other.
Also, what about slot-loading the driver and/or ports by having them aimed at the floor with a 1-2" gap to let the sound out into the cabin?  Good, bad?
Thanks, have looked on Google, but can't really find what I need.
Mike
munchichee
Copper - Posts: 51
Posted: August 13, 2004 at 1:03 PM / IP Logged
HERE is a good article on speaker aiming. Its a pdf file.
munchichee
Copper - Posts: 51
Posted: August 13, 2004 at 1:05 PM / IP Logged
I forgot you can spend days reading this site: BCAE I'm sure you can find some answers there cause I can't explain it as well as he does.
beady
Copper - Posts: 65
Posted: August 13, 2004 at 3:22 PM / IP Logged
munchichee, that first link only has one page and ackowledges a similar problem, but doesn't give any solutions.
I've read a lot on the second site, but I don't recall it talking about aiming of subs.
Thanks,
Mike
Ravendarat
Platinum - Posts: 2,806
Posted: August 13, 2004 at 4:25 PM / IP Logged
My favoirite box I ever owned was a 1.75 cubic foot box that was down firing with a slot port. It had a soluid lip around three sides and the fourth side was opened and aimed towards the back of the car. I had a dvc orion xtr 10 in it and it hammered. Aslong as your sub meets the requirements for downfiring i have always found this to be the best way to help eliminate hatch rattle.
beady
Copper - Posts: 65
Posted: August 13, 2004 at 9:09 PM / IP Logged
What does that mean?  I've never heard of a requirement for downfiring, can you explain please?
Imagine a box with the same setup you just described, but the enclosure is ported.  Could you vent BOTH the driver and the port through that slot formed by the three sides of the box with no problem?  That's what I was thinking of doing.
Thanks,
Mike
stevdart
Platinum - Posts: 5,816
Posted: August 13, 2004 at 9:59 PM / IP Logged
About downfiring requirements http://www.partsexpress.com/resources/downfire.html
beady
Copper - Posts: 65
Posted: August 13, 2004 at 10:24 PM / IP Logged
[QUOTE=stevdart]About downfiring requirements http://www.partsexpress.com/resources/downfire.html[/QUOTE]
Many thanks for that link.  I'd never heard of that issue before.
My JL10W3 looks like it comes out to about 2% so it should be fine.
Thanks again,
Mike
Ravendarat
Posted: August 13, 2004 at 10:59 PM / IP Logged
My enclosure was ported, as I said with a slot port. The port downfired as well as the sub.
beady
Copper - Posts: 65
Posted: August 14, 2004 at 9:44 PM / IP Logged
If you have a port that exits a box into a slot loaded configuration, does the slot length add to the tuned length of the port?  I'm talking you have a port firing downward from a box and the box has 3 "rails" holding the box up with one side open.  I can see if the slot port was the wame width and height of the outlet that it would probably affect it.  I'd guess if the slot port was significantly different in height and/or width that it might not affect the tuned length.
Ravendarat, do you know?
Thanks,
Mike
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
