8 ohm damage 4 ohm?
MBZ oe
Silver - Posts: 385
Posted: August 18, 2004 at 3:12 PM / IP Logged
Can you hook up a 4ohm sub to a home receiver thats rated at 8ohm to play at low volume for break in? Or would that somehow be bad for sub?
boom, boom, boom boom....
kgerry
Platinum - Posts: 3,455
Posted: August 18, 2004 at 3:49 PM / IP Logged
wouldnt be bad for the sub...it may be bad for the amp tho......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
DYohn
Platinum - Posts: 10,741
Posted: August 18, 2004 at 4:14 PM / IP Logged
Kevin is right, that is in general not a good idea.  Home theatre amps are rated for 8-ohms (some for 6-ohms) minimum.  And there are a few home amps that can handle lower loads, but be sure to check the owners manual for your amplifier and do not load it below it's rated specs!
