Whining noise
Pass the Roc
Copper - Posts: 51
Posted: September 11, 2004 at 9:52 PM / IP Logged
i get a whining noise from the speakers when i turn the engine on. It gets louder when i push the gas pedal down. I just installed my amp, headuint and speakers brand new. But i cannot figure out what is making the whining noise?
dpaton
Copper - Posts: 141
Posted: September 11, 2004 at 10:44 PM / IP Logged
Alternator interferance. Check that your power and ground leads on the amp are fat and well connected, especially the ground. It needs to go onto bare metal on the chassis. Power should run straight to the battery.
-dave
This is not a sig. This is a duck. Quack.
Pass the Roc
Copper - Posts: 51
Posted: September 11, 2004 at 10:45 PM / IP Logged
i have a good ground connection, right to the chasis of the car, it must be the power cable interfering near the alternator?
Charles_R_H
Copper - Posts: 122
Posted: September 11, 2004 at 10:49 PM / IP Logged
did you replace the factory speakers and they are running off of the amp?
or is the amp running subs and you have factory speakers running off of the deck?
have you tried wiring a return ground wire to the deck??
is the amp body on bare metal possibly??? or raised?
electronics run off of smoke, when you let the smoke out they stop working
Charles_R_H
Copper - Posts: 122
Posted: September 11, 2004 at 10:52 PM / IP Logged
have you tried running a return ground from the amp to the deck??
is the amp mounted flat to body or raised??
Charles_R_H
Copper - Posts: 122
Posted: September 11, 2004 at 10:53 PM / IP Logged
sorry didn't think the message went through a second ago
Pass the Roc
Copper - Posts: 51
Posted: September 11, 2004 at 11:28 PM / IP Logged
i have a amp running the speakers, which i replaced from factory, and installed new in doors. The deck is grounded at the same spot the amp is. The amp is sitting on the carpet of the car, not touching any bare metal. I do not ahve subs yet.
Charles_R_H
Copper - Posts: 122
Posted: September 11, 2004 at 11:42 PM / IP Logged
how long is the ground lead? are the amp ground and deck ground tied into together and grounded? have you tried not grounding them in exactly the same spot but close?
Pass the Roc
Copper - Posts: 51
Posted: September 12, 2004 at 10:20 AM / IP Logged
the ground lead is not long. the amp and deck ground are tied together and grounded. When i had the deck at a seperate ground, i got another noise comming from the speakers, tieing them together was the only way that solved this problem.
Asmodeus
Silver - Posts: 393
Posted: September 12, 2004 at 1:03 PM / IP Logged
Make sure that you didnt run your RCAs for the amp right next to the power wire comming from battery
Especially if the RCAs are the cheap kind this will cause Motor noise to filter over...
Whining noise -- posted image.
Making the World A Louder Place
