Xtant DVC 4 ohm Woofers/RF 501s amp
pumara_iep
Member - Posts: 19
Posted: September 15, 2004 at 7:38 PM / IP Logged
I have an Xtant Dual Voice Coil 4ohm Woofer Rated at 500w RMS and a 2 channel Rockford Fosgate 501s amp rated at 100w X 2 @ 4ohm, 250w X 2  @ 2ohm,or 500w X 1 @ 4 ohm. In order to wire these up (let me know if im wrong) is to wire in parallel with only one of the voice coil and that will put out 4 ohms. They Sound okay, but at higher gains levels they seem to make a weird noise as if something is rubbed on it, lets say if you put a pencil on the woofer when its running. I thought it was the letters on the woofer but it wasnt. Would that be a possible distortion?
I had them running  into a different amp. A 2 channel Logic amp rated at 150w X 2 @ 2ohms, or 300w X 1 @ 1ohm bridged. I had the subs wired parallel using both coils so it would put out a 2 ohm load. When i wired them up with this amp, the sub wasnt making that noise and it pounded sooo much harder. I loved it. Why isnt the rockford fosgate amp doing that when it seem to all match up? Could it be the amp? why is this 300w amp hitting my subs harder than the 500w rockford fosgate? Does the Impendence have alot to do with it? As you can see, im a newbie and a detailed description would be appreciative.
94legend
Silver - Posts: 237
Posted: September 15, 2004 at 7:53 PM / IP Logged
Its out of phase, you need to run them in bridged mode.
Your amp needs to load your subs  500 watts  @ 4 ohmz
Do this by running it off OPTION 2
Xtant DVC 4 ohm Woofers/RF 501s amp -- posted image.
94legend
Silver - Posts: 237
Posted: September 15, 2004 at 7:55 PM / IP Logged
This would series / parallel
forbidden
Platinum - Posts: 5,354
Posted: September 15, 2004 at 8:34 PM / IP Logged
WTF, I am reading this as you have one dvc 4 ohm sub and then in the same paragraph, it reads as though you have a pair of these subs, how many do you have?
pumara_iep
Member - Posts: 19
Posted: September 16, 2004 at 10:01 AM / IP Logged
sorry man, i wrote it wrong. Its only one sub. i have that habbit of saying sub, subs. No. there is only one sub. sorry for the throw off.
forbidden
Posted: September 16, 2004 at 12:12 PM / IP Logged
Thats what I was thinking, ignore basically everything up above. Your amp is stable to a 4 ohm mono load only. While it can and will run a 2 ohm mono load, it will do it for a finite period. Meaning it will go into thermal protection real damn quick. I do not recommend it at all. You can continue to operate the sub with one coil only or a better idea would be to wire the sub in series to 8 ohms, whle this may lower the overall output level of the amp, it is the safest way to operate this sub on this amp. A dedicted mono sub amp that is stable to either 1 or 2 ohms is in your future if this combination will not do what you need it to. A thing to remember here is that most if not all Rockford amplifiers will happily exceed their rated power ratings, especially in bridged mono. I bet that this sub will pound away quite well. Here is how to wire the sub properly.
Wiring Option #2
pumara_iep
Member - Posts: 19
Posted: September 16, 2004 at 12:44 PM / IP Logged
having it wired in an 8 ohm load, wouldnt that decrease the performance? wouldn't it be better to wire them up in a 4ohm load?
forbidden
Posted: September 16, 2004 at 1:27 PM / IP Logged
Like I said, the Rockford amp is underrated, run it in this fashion for the best performance, your sub is rated if I remember correct at 500w rms, split 250w rms per coil. So over 500 w rms into one coil could result in sss due to excessive heat transfer. Wire it in 8 ohms and play it safe.
DYohn
Moderator - Posts: 10,741
Posted: September 16, 2004 at 1:47 PM / IP Logged
Like Rob is telling you, you can't.  A DVC 4-ohm sub can be wired for 8-ohms or for 2-ohms.  You cannot wire it for 4-ohms.
pumara_iep
Member - Posts: 19
Posted: September 16, 2004 at 6:00 PM / IP Logged
couldnt i wire just a single connection? I thought DVC just leaves you with more wiring options. If i only wire up one of the connection from the woofer, i wouldnt be using all of the coils? im a newbie as you can see. just really curious. I thought it was okay to connect only one of the connections. If i used up only one of the connections and wire them parallel, It will put out a 4 ohm load. wouldnt it?
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
