1993 Camaro
93maro
Posted: September 25, 2002 at 8:21 PM / IP Logged
hey im having a problem with a Sony CDX2180 head unit in a 93 camaro z28. i recently installed it and it worked fine until i hit the next track button, and the sound just cut out. after turning the car off i came back to it later and the sound was working again, but then it cut out again. now it doesnt work at all, any ideas?
skiflyer45
Member - Posts: 33
Posted: September 25, 2002 at 8:35 PM / IP Logged
is the unit turning on or is there just no soúnd?
skiflyer
Sound Pressure
Silver - Posts: 711
Posted: September 25, 2002 at 10:46 PM / IP Logged
Maybe possible that the faceplate is not making good contact? Check the connections on the back of the faceplate to make sure that the contacts are clean.
Sound Pressure
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
