high level input went wrong, amp help?
taehwan_jkim
Member - Posts: 11
Posted: September 29, 2004 at 1:18 AM / IP Logged
it might sound kind of  confusing...my system is using a stock deck, so i tapped high level inputs to the subs.  i got new speakers, and i had this rockford fosgate 900 watt, 300 rms, 2 channel amp, so i hooked that up using a line output converter from the front speakers.  i was lazy so i tapped this all behind the deck and not at the speaker.  there happens to be a blue wire exactly the same size and color as the negative lead to the front right speaker.  this wire was the power wire to the deck. so i had cut this and thinking it was the speaker, tapped the end to the deck to the line converter, and thinking that the other side of the wire was going to the speaker and not the battery, ran that wire to the negative output of the right channel of the amp.  when i hooked this up, the amp obviously turned on i saw the indicator light.  the amp was getting power from the pwer wire into the negative channel, and it was already grounded.  i assumed that somehow the capacitor i had hooked up was giving it some juice, but it couldnt have been, the power wire wasnt hooked up yet(this was around 330 in the morning).  when i did hook up the power wire and turned it all on, the right side speakers ( which was recieving a positve output to its negative terminals) , buzzed for like 4 seconds, then popped, then the connection where  the battery output met the negative terminal output sparked.  so i figured this out after when i saw that the blue wires were hooked wrong, and set it back up right.  I hoped nothing was wrong and used a couple test speakers to the amp, they worked kind of messily on the left channel, but sparked when i would hook up the right channel, then it popped the speaker.  The next speaker i tried bridging the right negative(damaged terminal), to the left positive, and it still popped.  if you understand this and know if it can be fixed, it would greatly be appreciated...
thapimpfromchi
Silver - Posts: 616
Posted: September 29, 2004 at 1:29 AM / IP Logged
i have no idea what u just said. can u clear up the part about what wires u connected wrong, i understood all the rest.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
taehwan_jkim
Member - Posts: 11
Posted: September 29, 2004 at 1:34 AM / IP Logged
the constant power wire to the deck, i cut that, the end sticking out of the deck i tapped to the line converter( i thought it was the speaker going out), the end going out back to the battery(which i thought was going to the speaker), i hooked up to the right channel, negative terminal of the amp, so the problem was that pwer was going to the negative terminal of the right channel of the amp...get it?..
stevdart
Platinum - Posts: 5,816
Posted: September 29, 2004 at 7:18 AM / IP Logged
You'll have to pull that amp out and send it for repair.  Make sure you label all the wires before installing again.
taehwan_jkim
Member - Posts: 11
Posted: September 29, 2004 at 12:38 PM / IP Logged
can someone who actually knows what is wrong with the amp twll me something? obviously it needs to be repaired, im telling you that by posting this forum....
DYohn
Platinum - Posts: 10,741
Posted: September 29, 2004 at 12:55 PM / IP Logged
You probably blew your output transisters but NO ONE can tell for certain via an internet forum.  Take it in for repairs, like stevdart recomended.
forbidden
Platinum - Posts: 5,354
Posted: September 29, 2004 at 1:16 PM / IP Logged
My guess as well that you took out the output stage of the amplifier. You let the magic amplifier smoke escape and now it need to head for service.
taehwan_jkim
Member - Posts: 11
Posted: September 29, 2004 at 1:25 PM / IP Logged
where should i take it in, and how much do you think it might cost?
DYohn
Posted: September 29, 2004 at 1:37 PM / IP Logged
Take it back where you bought it, or to an authorized Rockford service center in your area.  Call them to find out who that might be.  480-967-3565
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
