Mid Bass
need2knowalot
Posted: October 06, 2004 at 8:37 PM / IP Logged
I do not know a lot about car audio but I have 2 8 in subs pushed by a Phoenix Gold 350 and 2 6 in subs with a Kenwood 250. Is there a way to only send the low bass to the 8's and the highs to the 6's? I know maybe it is a dumb question but i "need2knowalot".
Thanks for your help...
jeffchilcott
Platinum - Posts: 2,483
Posted: October 06, 2004 at 11:36 PM / IP Logged
well if you have a crossover on each one of your amps you would set the pG to LPF and the other amp to HPF     if you dont have this option you might have a sub out on your deck     you would run that to your PG..    if not, then you could purchase a EQ to seprate your frequency's and run your rca's from that to each amp
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
italnpimp59
Silver - Posts: 427
Posted: October 07, 2004 at 1:15 AM / IP Logged
an external crossover is the way to go.  you can set the cut off frequency to the 6in subs, and the 8in subs.  you dont want two different size subs playing the same frequency because it will cause cancellation
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
