03 Mazda 6
meh66
Copper - Posts: 266
Posted: October 07, 2004 at 9:15 AM / IP Logged
I am about to install two amps and speakers to work with the factory head unit. In my past experience, the only way you can get the head unit to control the amps was tapping the speaker wires. I was wondering if there were any module that allows you to get control of both amps or do I have to tap it twice?
MEH66
"Car Performance and Mobile Electronic Enthusiats"
audiopro111
Copper - Posts: 160
Posted: October 10, 2004 at 12:13 AM / IP Logged
you will have to use in-line converter taht goes connected to your rear speakers high input low frequency output  you may even get it on e-bay you can get the cheaper model that u have to run a separate remote line or spend a few more $$ just a few bucks and get the kind that have a built in remote line that only turns on when it sees a signal that way all u have to the front is a power wire from battery,i recommend at least a 4 Gauge if your powering up 2 Amps....Now as far as controlling both amp seperatly i would change the HU  and maybe add passive eq but if your staying stock you'll need rca splitters 1 male 2 females and your gonna need 2
AudioPro111
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
