Amp question
Thuan
Copper - Posts: 88
Posted: October 18, 2004 at 4:10 AM / IP Logged
I have a soundstream VGA800.5 and I'm not too sure on how to adjust all these knobs. I've had a system before and didn't know much so I use to turn everything on max. Hopefully someone can walk me through this because I'm lost. I'm running (1) JLW6V2 and (4) MB quarts RKC110's, what would you guys recommend i set the frequency and so forth at? These are the knobs I need help setting:
Subwoofer : Boost ( 0dB - 18dB ) ?
                       EQ ( 30Hz - 100 Hz ) ?
                       Gain ( MIN - MAX ) ?
                       Sub Sonic ( 10Hz - 100Hz ) ?
                       LPF ( 50Hz - 5KHz ) ?
  Coaxials :   Boost ( 0dB - 18dB ) ?
                     X-Over ( FULL, HPF ) which one should I go with?
Thuan
kfr01
Gold - Posts: 2,121
Posted: October 18, 2004 at 9:23 AM / IP Logged
Whatever you do don't simply turn everything to the max.  Have you seriously done this in the past?  You risk damaging your equipment and your hearing and making your system of otherwise decent stuff sound like a jhuge joke.  Check out http://www.bcae1.com and try to learn what all these things do.  http://www.crutchfieldadvisor.com/ and your manuals are also good sources of information.
1) turn the LPF on .. it should be around 100hz
2) turn the Sub Sonic on .. start at 20-25hz, higher if you have a ported or bandpass box
3) Leave the EQ and BOOST off for now.
4) those sites will have step by step guides to setting gain .. follow it carefully .. this step is very important unless you want to damage your speakers
coax
1) turn HPF on, use 100hz .. maybe 120hz or higher .. what size speakers are those?
2) sub sonic should be off .. lpf should be off
3) gain should be set according to those sites .. again .. this is reall important
4) boost and eq should be off
Anyway .. hope this helps
New Project: 2003 Pathfinder
Thuan
Copper - Posts: 88
Posted: October 18, 2004 at 2:33 PM / IP Logged
Should I always keep the boost and eq off?
Thuan
Thuan
Copper - Posts: 88
Posted: October 18, 2004 at 2:47 PM / IP Logged
Im still unclear on how to set gains....I went to that link you provided me but I'm still confused.
Thuan
stevdart
Platinum - Posts: 5,816
Posted: October 18, 2004 at 8:40 PM / IP Logged
Read through these posts and you will surely find a couple of different tried-and-true ways to do it.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
