Acousticaly Tuned?
lolzitsmtss
Copper - Posts: 174
Posted: October 26, 2004 at 9:25 PM / IP Logged
How do you make your vehicle Acousticaly Tuned?
I guess that guy has subs.
Rushman
Silver - Posts: 380
Posted: October 26, 2004 at 10:50 PM / IP Logged
lots of dampening material , lots of research and trial and error. Lots of money (ha-ha) no really , lots of money. Knowing where to place speakers in relation to the drivers seat. Too many extra's to add.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
vdubmk4
Copper - Posts: 175
Posted: October 26, 2004 at 11:10 PM / IP Logged
When you say acoustically tuned, are you refering to your system being tuned correctly or you car behind turned into a concert hall ?
Fortune: You will continue to take chances, and be glad you did.
lolzitsmtss
Copper - Posts: 174
Posted: October 27, 2004 at 8:36 AM / IP Logged
The car into a concert hall.
lolzitsmtss
Copper - Posts: 174
Posted: October 27, 2004 at 8:37 AM / IP Logged
"lots of dampening material , lots of research and trial and error. Lots of money (ha-ha) no really , lots of money. Knowing where to place speakers in relation to the drivers seat. Too many extra's to add. "
So the New GMC Envoy has Dampening material all over the car? and alot more speakers then standard cars?
DYohn
Platinum - Posts: 10,741
Posted: October 27, 2004 at 10:14 AM / IP Logged
You'll need access to an anechoic chamber, rollers for your driven wheels so you can simulate running at highway speed, a wind tunnel, several calibrated pink noise sources, several channels of RTA and calibrated microphones, several strain gages and vibrational/velocity transducers, a good oxy-acetylene torch and a better tig welder, sheet metal, access to a variety of different interior treatment materials like fabrics, carpets, seat covers, etc., lots of sound dampening materials, better seals and gaskets for all windows, and lots of time and patience.  It might also help if you had access to an acoustical engineer.  Then, after you solve all the issues with the vehicle's construction, you can begin to choose your sound system components.
Rushman
Silver - Posts: 380
Posted: October 27, 2004 at 11:04 AM / IP Logged
I think I know where your going with this lolzitsmtss.........Does this have anything to do with the GMC commercial on TV? Where they ask if a concert hall can be accousticly tuned , then why cant your truck? If a 60,000 seat stadium can have a retractable roof , then why cant your truck? If an offraod Baja 1000 racer can have 4 wheel active suspension , then why cant your truck?
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
DYohn
Posted: October 27, 2004 at 11:25 AM / IP Logged
... and the real answer to those questions are corporate profits, weight, and CAFE standards.  It is a clever commercial, though.
lolzitsmtss
Copper - Posts: 174
Posted: October 28, 2004 at 2:07 PM / IP Logged
Yeah rushman..exactly. Saw the commericial and thought..How the hell can they do that?
P.S Dyohn..whats the best sound deadning material that you would say is the best....according to your preference?
DYohn
Posted: October 28, 2004 at 3:04 PM / IP Logged
Dynamat, Brown Bread, Dayton, Gator Skin, generic no-name... In my experience it all functions pretty much the same as long as you take the time to remove the car's interior treatments and properly install it.  I say use what's available the cheapest in your area.  Actually you can use just about anything that will reduce structural resonance.  I've seen good results using standard home carpet pad, wool blankets, foam rubber, roofing tar....
