jbl 1200.1
ampman
Member - Posts: 34
Posted: October 31, 2004 at 8:01 PM / IP Logged
I'm thinking of getting the JBL 1200.1. Its rated 1200 at 2 ohms. My speakers are the 8122 Eclipse. I believe they are single voice coil 4 ohms at 450 rms a piece. Is there any way to get these two subs wired to 2 ohms for this am
Alpine Guy
Platinum - Posts: 2,478
Posted: October 31, 2004 at 8:25 PM / IP Logged
yup, just hook both + from each sub to the positive on the amp, ,and both - on the subs to the - on the amp, , that will get you a 2 ohm load.
ampman
Member - Posts: 34
Posted: October 31, 2004 at 8:28 PM / IP Logged
Thanks.
jeffchilcott
Platinum - Posts: 2,483
Posted: October 31, 2004 at 8:46 PM / IP Logged
I was thinking most of the aluminums and higher were DVC   take a look and see if there is 2 set of terminals,    also if the 22 at the end of the model is like the ner series subs then you would have dual 2    you would have to wire each sub in parallel, to get one ohm then wire the 2 subs in series to get your 2 ohm load
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
uthinkuknoaudio
Silver - Posts: 760
Posted: October 31, 2004 at 8:49 PM / IP Logged
JBL amps kick a$$. Great power for the money.
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
audiobass10
Silver - Posts: 328
Posted: November 01, 2004 at 9:03 PM / IP Logged
Good amp..Keep in mind it doesn't have a subsonic filter. So if you plan on putting the subs in a ported enclosure...it would be in you're best interest to buy an F-mod (20 hz should do the job). They're around 25 bucks online. Best place to go for the JBL 1200.1 is www.sounddomain.com ..you can get it refurbished off there for $200+ shipping. Great deal. You can also look into the Refurbed DEI Audio 1100D on www.ikesound.com ..that's in the same price range and it would be a little less power than the JBL..I just realized what subs you're runnin and 600wrms to each of those eclipses might be too much daily..maybe not though. Just a suggestion.
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
ampman
Member - Posts: 34
Posted: November 02, 2004 at 1:21 AM / IP Logged
Isn't the JBL 1200.1 a mono amp? And doesn't a mono amp only have one channel? It looks like it has two. Will I have to bridge it to get 2 ohms out of it?
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: November 02, 2004 at 3:12 AM / IP Logged
Keep in mind that if your head unit has 4 volt outputs, the gain should be turned all the way down.  It will produce full power at that point, and you will be clipping the signal if you have it turned up any.  Also note that the amp has tested over 1400 watts in the magazines, so they are under rated.  I think that amp is responsible for the death of more Brahma's than any other amp just because the customers didn't understand how to set it up right.
Steven Kephart
Adire Audio
ampman
Member - Posts: 34
Posted: November 02, 2004 at 3:18 AM / IP Logged
All the way down? Really? I don't understand.
chevyman26
Copper - Posts: 227
Posted: November 02, 2004 at 8:48 AM / IP Logged
You are probably thinking of the gain as a "volume"control, which it is not. The one and only function of a gain control is to match the amplifiers input sensitivity to the headunits output voltage. It should be set (correctly) and never touched again. Check out this link - http://www.jlaudio.com/tutorials/index.html  and click on Interactive Input Sensitivity "gain" setting tutorial.    I don't think that a 1200 watt 2 ohm amp is listed on their chart so you can use the formula (P*R)^.5.  This will give you a voltage of 48.99 VAC. (you'll see what I mean)
I don't know this amp, but if it is mono and has two sets of speaker terminals, it is probably internally bridged, meaning that the 2 sets are just for wiring flexability (i.e. if you hook up a 4 ohm woofer to eack terminal the amp will see a 2 ohm mono load.) Like I said - I don't know this amp, so do NOT hook it up like this untill you find out for sure.  I'm just trying to point you in the right direction in your quest for knowledge...although I am pretty tired right now, might be just typing in my sleep, lol.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Page of 3
