Running a 4ohm amp to 1ohm sub.
dominicb
Member - Posts: 12
Posted: December 13, 2004 at 1:14 AM / IP Logged
I have a kenwood kac-929 amplifier that puts out 460watts at 4 ohms and I don't think it is 2 ohm stable at one channel.  But I have an audiobahn awt10x that is dual 1ohm and run in series I can have a 2 ohm load.  I had this amp running it before and had no problems.  I am looking to sell this amp and get a new one that matches up better to the 1000watt rms rating.  Will this be a problem running a 2ohm sub off a 4 ohm channel amp??
kfr01
Gold - Posts: 2,121
Posted: December 13, 2004 at 1:17 AM / IP Logged
Just buy a 2-ohm stable mono amp... What was your question?
New Project: 2003 Pathfinder
hwyranger
Posted: December 13, 2004 at 1:29 AM / IP Logged
It will be a little hard on the amp, especially if you listen to it loud.  Just get real amp.
stevdart
Platinum - Posts: 5,816
Posted: December 13, 2004 at 7:46 AM / IP Logged
...That would indicate that the amp is stable at that load.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
