Setup Q’s?
mrdragon
Copper - Posts: 121
Posted: December 13, 2004 at 10:14 PM / IP Logged
Kenwood Kac-626 specs...
http://memimage.cardomain.net/member_img_a/702322_14_full.jpg
Sub specs.....
2 12" Kicker EX1204 125RMS each into 4 Ohms (SVC)
Someone show me what is the best setup i can wire this system???
Cheers :)
/r7
Silver - Posts: 340
Posted: December 13, 2004 at 10:34 PM / IP Logged
by my gathering
your amp is 2ohm stable, so with those 4ohm svc's this looks to be about right
Setup Q’s? -- posted image.
kfr01
Gold - Posts: 2,121
Posted: December 13, 2004 at 11:38 PM / IP Logged
Whoooa... wait up there a sec. I think you may be wrong on this one /r7... You'd be right on if that amp really was 2-ohm stable MONO, but that's a 2-channel amp, right?
Almost ALL 2-channel amps are not 2-ohm stable when bridged. Many $1000 2-channel amps are not 2-ohm stable bridged!
You amp would be short lived, I'm afraid, if you wired it like that.
Either wire it in series, giving the amp an 8-ohm load bridged, and dropping your wattage by about about 1/2, or run each channel to a sub (stereo mode).
I hope you see this mrdragon!
New Project: 2003 Pathfinder
mrdragon
Copper - Posts: 121
Posted: December 14, 2004 at 2:29 AM / IP Logged
Thanks kfr01 i got ur private msg. I got another amp, but diff brand and model...do you recommend me BRIDGED each amp to run each sub??? I did try last time but its very hard to get both diff amp to match each other. Or it can be done???
kfr01
Gold - Posts: 2,121
Posted: December 14, 2004 at 2:54 AM / IP Logged
So... tell me about this other amp. You now have 2 amps?
mrdragon
Copper - Posts: 121
Posted: December 14, 2004 at 3:09 AM / IP Logged
Ok here is the info on my another amp....
http://memimage.cardomain.net/member_img_a/702322_15_full.jpg
kfr01
Gold - Posts: 2,121
Posted: December 14, 2004 at 11:32 AM / IP Logged
Why don't you sell those two amps and get one 2-ohm stable mono class-d amp? It would be far more appropriate for you. I don't like the idea of trying to shoe-horn something together, do you?
/r7
Silver - Posts: 340
Posted: December 14, 2004 at 12:05 PM / IP Logged
my bad, thanks for saving his amp ;p
btw i looked at the spec sheet again and if i was paying attention, and as you said, its not 2Ohm stable.
stevdart
Platinum - Posts: 5,816
Posted: December 14, 2004 at 12:13 PM / IP Logged
What I want to know is, mrdragon down under:   do you do installs for a lot of other people or do you keep switching up stuff for your own system??
mrdragon
Copper - Posts: 121
Posted: December 14, 2004 at 5:44 PM / IP Logged
Just for my own use....i am on tight budget atm.
See atm i am running 2 12" and my amp can only produce 50RMS per sub...and i was think if i can double the power by putting in a second amp...then why not...since the second amp can only max 100RMS.
